alaskanzx5 Posted November 16, 2013 Report Posted November 16, 2013 Just picked it up from a member on here, well didn't know he was a member until he said he was. Said he hasn't been on here for a while but he lives in Indiana and has a Monte Carlo with 218" dd walled. Very impressive build. anyways, i'm looking for a slot ported box sub up port to the side. Usually I would just throw numbers around on Torres and double check running but don't have my computer right now. Max dimensions are 19" high 19" deep 40" wide Looking for a mid 30 tuning, around 34-36hz. Thanks for the help t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
CleanSierra Posted November 16, 2013 Report Posted November 16, 2013 14" Height 14" Depth 31.5" Width Port 12.5" Height 2.5" Width 28" Length Tuned at 35 Hz, L-port on same face/baffle as subs(If you literally meant fired out the side of the box, length of port should stay the same regardless) Net space 2 cubes and 31.25" of port Slighty bigger box Change width to 35.5" and port length to 22" for a ~34/35 Hz tune and 2.5 cubes net Im not the one you want to try to troll. Just a fyi for you.
alaskanzx5 Posted November 16, 2013 Author Report Posted November 16, 2013 It's a hatchback i'm gonna do sub up port to the driver side. Those measurement will work great. Is that a double baffle though? t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
alaskanzx5 Posted November 16, 2013 Author Report Posted November 16, 2013 I think I'll go with the bigger box to, I have a lot of mid and high compared to 200 rms to that sub. bigger box will hopefully give me more output. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
CleanSierra Posted November 16, 2013 Report Posted November 16, 2013 I did not figure a double baffle though you can just add it and take away .75" on port length Im not the one you want to try to troll. Just a fyi for you.
alaskanzx5 Posted November 16, 2013 Author Report Posted November 16, 2013 I'll have about 4.5" of space between the port and trunk wall. Sub as for from the port opening as possible rounded off with a 3/4" bit. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
alaskanzx5 Posted November 16, 2013 Author Report Posted November 16, 2013 I did not figure a double baffle though you can just add it and take away .75" on port length I'll just add a brace from the port wall to baffle centered the best I can t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
CleanSierra Posted November 16, 2013 Report Posted November 16, 2013 Oh yeah, definitely give it the bigger box. I didn't realize you weren't gonna send close to RMS to it. Im not the one you want to try to troll. Just a fyi for you.
alaskanzx5 Posted November 16, 2013 Author Report Posted November 16, 2013 Oh, lol... Gotta use my 4 channel for now later i'm gonna get a 300.2 so it won't see over 300rms. It's just a temp setup until I get the all my stuff here Michigan. once that happens the hx2 will be taking out, the 300.2 will be used for 8" mids and I'll have 2 15" subs on a 1500.1bdcp until I can buy a 2500.1bdcp t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
rockFord_Expedition Posted November 16, 2013 Report Posted November 16, 2013 Very nice subs btw. Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
