alaskanzx5 Posted November 16, 2013 Author Report Share Posted November 16, 2013 I know, I want to do a psi recone for more power and put a t2500.1bdcp on it. Want to see what I can get it to do on a meter. Want to keep the original dust cap and see if I can get a carbon fiber cone whenever I recone it. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz. Link to comment Share on other sites More sharing options...
CleanSierra Posted November 16, 2013 Report Share Posted November 16, 2013 The Team RF cone of very sexy Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
alaskanzx5 Posted November 17, 2013 Author Report Share Posted November 17, 2013 Got back to my computer and got a cut sheet and box designed on sketch up. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz. Link to comment Share on other sites More sharing options...
alaskanzx5 Posted November 17, 2013 Author Report Share Posted November 17, 2013 http://southbend.craigslist.org/ele/4160898856.html That's the one I got, paid $90 for it and the could look fantastic. Still feels new with no rub. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz. Link to comment Share on other sites More sharing options...
alaskanzx5 Posted November 17, 2013 Author Report Share Posted November 17, 2013 The Team RF cone of very sexy You have die exp with the hx2 power series.right? do you think it would handle a t1500.1bdcp at 4 ohms? I see no issue in it. Just an idea for when i'm building a box for my 2 15 after i.e. them here to MI. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz. Link to comment Share on other sites More sharing options...
CleanSierra Posted November 17, 2013 Report Share Posted November 17, 2013 It should handle that amp at 4 ohms without a problem. Whats that thing rated at 4 ohms, like 600-650 at most. Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
alaskanzx5 Posted November 17, 2013 Author Report Share Posted November 17, 2013 Around 1000-1100 if I remember right according to the birth sheet. Just wasn't sure Because of the speakers age, either way eventually i'm gonna push it past it's limit to have a.reason to recone for more power. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz. Link to comment Share on other sites More sharing options...
CleanSierra Posted November 17, 2013 Report Share Posted November 17, 2013 Yeah 1000 probably is a lit for its age. I didn't realize the T1500 put out so much more than a T1000. My T1000bd is rated at 350 for 4 ohms. It makes competing nice though since certain organizations/classes go off of the amps 4 ohm rating. I say let er rip dude. If you have to recone, do it when it's needed. Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
alaskanzx5 Posted November 17, 2013 Author Report Share Posted November 17, 2013 yeah, I figured it would be ok just wanted a second opinion on it. after I get my stuff here to MI ill run it at 4ohm on the t1500.1bdcp until I get a box made for the 2 15"s then wire the hx2 to 1ohm on the 1500.1 and see how long it lasts. stuff to for the box 1 sheet mdf wood glue screws primer black paint blue paint clear coat sand paper liquid nails router bits t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz. Link to comment Share on other sites More sharing options...
