Small compresser for home use
evermaxx
3/8 is fine if you have 120+psi
most of the tiny ones top out 100-110 though, so yeah, 1/2 line can help.
Hammerdown... 1%
I have a 3 gallon for tires and stuff. It will run a an air nailer but kick on way to F***ing often. And I have a 30 gallon for everything else. Do I miss my 60gallon, yes I do. You will find you start using more and more air tools once you have a compressor and then you be mad cause you started with a compressor that was way too small
