Memory Problems
I have an old Dell Dimension 2400 desktop that I got from a family member. It's a decent computer for it's age, built back in 2004. Problem is the memory. When I got it, it had a 256mb and a 512mb memory in it. Something happened to the 256mb so I was only running the 512mb. I did a little looking around and noticed that according to dell the computer can support up to 1.5gb, but according to Intel it can support up to 2.0gb. I ordered two 1gb memory cause for one I thought my computer could handle it, and cause some of the programs I use for school require 2gb. Was I wrong in assuming that my computer could support 2gb?
did you make sure it was 333mHz
it will handle 2gb
DIMM is 184 pin ram
http://reviews.cnet.com/desktops/dell-dimension-2400-pentium/4507-3118_7-30824846.html
skar sk2500.1
0 gauge power and ground kunukonceptz
alpine HU
vxi65 components on BA gt-275
new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821
2 x-15 sundowns
singer alt, odyssey bat, and maxwell ultra caps
I did change a few things when I was only running 512mb to get a little better performance out of the computer, but I don't remember the factory settings. I don't know if that is affecting what's going on now or not. I would set the computer back to factory, but I don't have the discs to reinstall everything. At least I think I would need those discs on a computer this old.
you may have to set the timings and voltage for the new ram
prebuilts like that tend to have the BIOS crippled so you can't change that stuff iirc
2016 Ford Focus SE
No build log yet
DC Audio 1.2K
2x DC Audio Level 2 10"
http://www.dell.com/support/drivers/us/en/04/Product/dimension-2400
If you have windows XP cd Those should be the drivers it. There is service tag that should tell you exactly what was in the machine. Don't know if that will help your problem, but if you wish to format it Those maybe the drivers needed.
2007 Ford Ranger
(ALL YET TO BE INSTALLED - DUE TO WORK SCHEDULES)
K&N Performance Air Intake
Massive Audio D2400 Mono Amplifier
2 Custom Built 8" Subwoofers in Ported Enclosure
Pioneer AVH-P4400BH In Dash Double Din DVD Player (Video Bypassed)
4 - Pioneer TS-A6886R 6" X 8"
2 - SMD Heavy Duty Single ANL Fuse Blocks
2- Stinger SPP1200 Dry Cell Batteries
JL AUDIO Interconnects
2/0 Gauge Big 3
ILL Customz 8 Spot Flat Lug Style Bolt Down Terminals
ILL Customz 1/0 to 4 Gauge Power / Ground Reducers
Factory Alternator
__________________________________________________________________________________________________________________________________
2002 Cheverlot Monte Carlo SS - (Deceased)
2 - Rockford Fosgate Power 1501BD
1 - Rockford Fosgate Power 851x
Rockford Fosgate Power 6 1/2 Components
Rockford Fosgate Power 3 way 6x9
2 - JL Audio W7 13.5" Subwoofers (Sealed)
Pioneer AVH-P4400BH In - Dash DVD Player
Pioneer AVIC - U250 - Add-on GPS Navigation System
Audio Control 6XS 4 Way Crossover / Line Driver
Ohio Generator 200 Amp Alternator
3 - Stinger SPP1200 Batteries
1 - Optima D34/78 Battery
