4th order blow-through in 2008 F-250
Very nicely done. Are you planning to plexi the top there? Also how did you put those studs in the wood? Threaded inserts? I don't think I've seen it done like that before.
What year F250 and what's the overall dimensions of the enclsoure? I was thinking about a 4 12 4th in my 94 f 350 in the future.
I don't think i'll do the plexi because this is still an experiment. Once I know this box works I might.
Yeah the studs are pretty badass, they have a wood side and a reg machine side and i put them in with Gorilla glue. I used them because I'm a dumbass and couldn't find the threaded inserts but I think for that application they might work better.
the dems are 30 x 50.5 x 17 and those would work in your truck because Ford doesn't change anything between those years except the front clip. though the 17" should be more like 16.5 but I knew I was making the front thick because of the top.
