How to set gain on saz3000 when max gain is 6v but line drivers 8v
Deadly hertzz
It's an audio control overdrive it worked good for my last setup but I just figured someone would know what track to use for it nothing in the manual nothing on YouTube if I don't figure it out today Ile just remove it it was like 100 bucks so i guess I just didn't want it sittin n the crib not getting used
8 sundown sa 12s walled
Saz3000 at .5
HO alt
All ofc Sky high wire
Alpine components
Rockford power mids
imagesCAA9EA5N_zps0f411022.jpga5ec9a01-b60c-4312-9001-236b48dfe6b0_zpsb01ef146-7fd0-47c3-90e9-f1a2d4595b03_zpsimagesCATNMRMV_zps66a8566a.jpg
Treat it like your head unit. Same track. Id honestly see about leaving it down as far as possible since you dont really need it. As long as its clean and you arent blasting the output voltage it wont hurt anything
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Should I use track 1 or 2 tho the 40 or the 1khz cuz I'm supposed to average those to get my
Head units max and I can't really average the line driver the same as I did the head unit that's the part that's confusing me if all else fails Ile take out the line driver and do a lot of re arranging to just run straight RCAs to the amp
Saz3000 at .5
HO alt
Alpine components
Rockford power mids
What are you running off the line driver both amps or the sub amp?
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
How are you checking it? Can you post some pictures.of this set up. I cannot get a visual of whst you are doing
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
And whst signal are you feedijg the line driver. A sub signal into your subamp or a high pass signal into your mids and highs amp
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
  • Who's Online   1 Member, 0 Anonymous, 1071 Guests (See full list)
