*sticky* Free Tech support
Guest MegaloManiac
so just rip that carpet off and glass over that pretty much...
http://smg.photobucket.com/albums/v643/din...ent=console.jpg
mad tyte paint skillz.
well what you will do is leave about 3/8" below the very top of the sides of the fact. console, that way once you put your finish panel with vinyl on it will flush out.
so now you have your base and the sturdy side pieces in there, make a plate to mount the deck and knobs, and rom drive in it, then copy that onto a piece of 1/4" mdf and set it aside for now.
attach the main panel to the rest of your base pieces, and check fitment of the 1/4" panel, it can be a little off at this stage.
mount the radio and drive along with whatever else you want to put in it, and place the 1/4" panel over the top and check for fitment.
now to finish it up tape off "(3 layers of masking tape)"the radio trim ring, knobs and rom drive, place the panel back on, now use your fav. body filler and push the filler up onto the tape on all pieces.  Let it dry then pull the 1/4" panel off, and trim down to what ever shape you want.
Checking fitment along the way, once that is done repeat those same steps but tape off the factory console side pieces.
Now your panel should fit the factory console like a glove and fit around your aftermarket equipment with just enough room for vinyl.
lmk if i need to explain more..
or if my method suxx.
u got it mang..
and no more ghey shit..lol
piece of cake.. done in 6 hours.
Guest MegaloManiac
u got it mang..
thats a watermark so no one steals my design
Gay love professions FTL  i no comprehdeee  ???
intraweb noob<<<
Guest MegaloManiac
im saying the same thing you did, it looks gay haveing megalo loves ray
its reffering to you raY :NAUGHTY:
j/k
tomarros high is 62degrees. is it ok to glass in that temp? or will it take the whole day to cure?
