*sticky* Free Tech support
Well you want A challenge? I might have one. I have a 1986 pontiac firebird. I did the calculation of the cubic feet in the trunk "well" the dip in the trunk in the very back. And its 12.7 cubic feet. I'm trying to find preferably 2 12's that could fit back there and give me the best bang for my buck. And I would prefer to make it ported because I listen to hip hop mostly. So what would be a good amp/sub combo that could best use that kind of space?
Looking for your opinion. My door panel has me worried in a few spots. I know pics aren't the same as seeing it but could these two spots be wrapped with vinyl? Just laying a piece of vinyl on it seems impossible but I know heat and stretching makes a difference.
2013 F150 Crew Cab
Old Build Log
Feedback
2013 F150
Where is that speaker ring going?
And 86 with 12cuft back there??
I think you did the math wrong.
Get 4cuft and do whatever 12's you like.
Go listen to some setups and make your own descision.
The fiberglass will be along the bottom half of the door. Planning to keep most of the original shape without a pocket though. Just worried about those two sharp corners and the vinyl not stretching. The top darker part will stay the color it is. The arm rest is its own piece and so is the armrest cushion. I can take a better pic tomorrow and point out corners if that would help. I thought I was ready to go on these now I'm worried I'll get to the end and mess up or not be able to wrap those two spots.
2013 F150 Crew Cab
Old Build Log
Feedback
2013 F150
not sure if this falls into your realm ray....
i gutted my alarm/remote start (automate....DEI) out of my jeep the other day since im putting the alarm portion in my pt soon....i had no window mod or anything of the sort
previously i had ran speaker wire though the door moldex (since i had blank holes) in both doors
hooked up new speakers then ran it to the dash cavity and hooked it up to the stock radio (its my moms car now so i put it back to stock) so i sniped all the speaker wires on the radio harness off and hooked just the front channels up to the speakers....
now the pass. side windows/locks are intermitent, i dident snip any wires in the moldex plug, and they were all working fine before the alarm gut/speaker install
da fuck did i do lol, i mean i really gotta get in there and look at it myself i know that, i havent had time, but maybe you can save me some time and hopefully point me in the right direction if possible
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
Not working at all would be cut wires
Intermitent means maybe bad switch??
And more pics robert
Hey Ray i was wondering if u know if a set of DD VO B2s will fit in a 2005 dodge magnums stock dash location without major mods. Cut out diameter is 3.55" mounting depth is 2.4"
You will have to cut a bit.
will i be able to cut it there or will i have to take the dash apart? And will they sound good reflecting of the windshield?
