Head unit losing memory?
sbg
So I have had my new pioneer avh-x3500bhs for a month or so. And I am having a problem, about every 5 days or so it is losing memory. I come out and start my car and the memory is reset. Then I have to do all my settings all over again. Does someone know what my problem is? O and car is 2013 kia sportage.
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
Bump
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
No help :(
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Easiest thing to do is make sure wires are solidly connected, if that checks out try another radio and see if the second one does it as well. If it's only a month old take it back and exchange it.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
^^^what he said, also Make sure all your wires are hooked up properly like ign wire and cosnt arent switched
05 Escape
2 Ascendant Audiio Mayhem 15s dual 1
Populus Audio 6500 (the only one around )
1/0 SHCA OFC
XS 3400 under the Hood
XS 3100s in the rear X2
Pioneer 80 Prs
Pac
Prv mids and highs
2 8s per door 1 tweet
I had the same issue.. Wiring was not solid enough..
sometimes Loud is NOT pretty
Sounds like its safe to go ahead and bend that ass over.
Did you do the amazon micro bypass? Same thing is going on with two of the same units I installed. Same model. And both have the micro bypass.
2003 Tahoe
dc 7.5k
dc level 5 15's (3)
MMats 341's
xs power batts
lots of sky high cable
dual alts(came off the sky-high gmc and don't know who made them)
ipad in center console
vu-din in center console
all being ripped out and being sold
No micro bypass, just used a toggle switch. I will check my wiring to make sure it's solid but I'm sure it is. And 100% sure that it's wired right.
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
I mite just take it back
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
I was just thinking, I never looked to see what way the toggle switch was facing. Like on/off so i went and took a look. I have it that if you push it up and then back down, it's at the ON. So It has been left on the on postion all the time. Now that I know up is off and down is on I hope that fix's the problem.
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
  • Who's Online   0 Members, 0 Anonymous, 1025 Guests (See full list)
