All you really need since you're on a budget is a 2 channel amp, by hooking two 4 ohm speakers to one channel you'll be at 2 ohms, so look for a amp that will give you around 200 RMS per channel @ 2ohms. Or a T4004 would be perfect for each speaker on it's own channel, that way you could keep a front and back channel, diff ranges.
I have this dream of this underground culture in mind, coming to life through the Audio that I build, Deep Perfection.YUKON'S SITEhttp://www.cardomain.com/ride/2397609
left and right.
I two channel amp can keep your right and left. Why do you think Head Unit's have Front and Rear RCA jacks? It's due to the timing Recorded onto a CD. It's the four focus points on sound. FL,FR,RL,RR. all diffent timings. I record music also, so I know it's process. Cleaner Clear will also be a four  channel amp with a speaker on it's one channel, lower the ohm Less THD%
