Door speaker install problem
ReeseChamp
i bought a pair of RE audio 5x7(6x8) and i go to install them and the stock speakers use wiring harnesses(i think you call it) but my speakers are the normal wire kind(im a beginner at audio)
what can i do to make them work? do i have to wire new wire from the stereo through the door, or do i have to get a wire harness and solder it onto the speaker? i dont have a soldering iron tho
Subs - Dual RE Audio SXX v2 15D4 wired at 1 ohm
Door Speakers - RE REX 5x7/6x9
Battery - Kinetik HC 2000
Sub Amp - Crescendo BC2000
Door Amp - Alpine MRP-F300
Head Unit - Pioneer DEH-X8600BS
you can just cut the wires and connect them positive to positive and negative to negative..
running new wires would be a good idea since the stock ones are way too small..
sometimes Loud is NOT pretty
Sounds like its safe to go ahead and bend that ass over.
i plan on running all new wires and such when i get a 4 ch amp im just running off a 4 ch stereo right now, and i dont know exactly how im supposed to do that heres a picture of how the speaker plugs in, on the bottom right
2 ways: either tap into the factory wires, just cut the plug off and then terminate the positive and neg. Or you can bypass the factory speaker wiring and run your own speaker wire, what ever size is suitable, most commonly 14-16 gauge. Depends on the car and what size speaker wire you need. I'd just run new wires if it's easier for you.
For the terminals just get some female spade terminals to fit on the pos and neg on the bottom of the speaker.
Ipad mini as main source unit, w/ Kenwood KDC-U7056BT,Digital Designs CS6.5 2 way components, Alpine PDX-F4 4 channel & PDX-M6 mono, x1 Jbl P1224 12", single ported box @ 34hz, front doors + trunk sound deadened w/ dynamat xtreme,all knukonceptz wiring/fusing.
*In progress - Audison bit ten d dsp, fully optical.
well i just went out i was gonna cut the harness off and wire pos to pos but i found a slight problem, which one of these is the pos and which one is the neg? both doors got diff colorsimage.jpgimage.jpg
forget the pictures i went into a website that shows all the stock wiring in my car so i know which is which thanks guys
Use a multimeter on dc voltage to test the polarity (positive or negative)
  • Who's Online   0 Members, 0 Anonymous, 1427 Guests (See full list)
