gattiboy13 Posted December 6, 2013 Author Report Posted December 6, 2013 Problem fixed he placed a new battery in and all readings were great sitting at 2200 cranking amps and 1000 cold cranking amps. The one put in before was sitting on shelves so long it was dead pretty much. And yes I guess you can cut power wire and solder larger wire to it.
DubNDodge Posted December 6, 2013 Report Posted December 6, 2013 Yes you can. Should you? No. What should have been done was get the proper size battery for your location so that the stock wiring would reach. OR Just go ahead and do the big 3 upgrade, assuming that you make a new run to the fuse/relay center if needed. And then tape up any raw ends and zip tie them so they aren't loose in the engine bay. If they weren't able to be removed. x2 on what Kranny said. I want to see what is under that shrink wrap. Oh well. '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
