box build for T1D2 12" Pros & Cons (edited dimentions)
bcbrassard
I built this box a year ago and since then my knowledge has grown and was looking for opinions & suggestions on what i did right or wrong. And what i can do to improve current set up with areo ports if need be.
Box dimentions: (inside box dimentions)
36.5" W x 14.5" H x 10.5" D = 3.116929 Cu ft
RF T1D2 12" displacement =.308 Cu ft
Box after speaker = 2.808 cu'
Ok i wanted it to look cemetrical and centered the sub w/ areo ports on either side(bad idea looking back now)
Areo ports cut to 9.85" for a tuning of 42Hz but there is only 2" of space between the back of enclosure to end of flared port inside.
Question: is that enough room for proper firing & loading? The box sounds good, but i dont have anything else to compare it to so i dont know if it would sound better in a different set up or design.
Any input is appreciated. Considering rebuild box this summer. Adding another T1D2 12" and doing a blow thru from rear deck into cab.
Sub in 1 ohm being powered off a RF Power bd1000a1, Thankjs for any help, heres a pic if that helps.
03LancerStereoBuildPart1021_zps2a805da0.
Okay I haven't finished reading yet, but already notice something.
The cubic feet gross of the box is actually 2.37.
I'll edit in if I see anything more.
Edit:
Assuming those are 4 inch aero's 9 inches long each, that brings your tuning to ~49hz.
Net volume comes out to ~2.1 cubes. Which is okay for that woofer. But the tuning is pretty damn high. I'd drop it down to like ~35 or so. You may have to go with a slot so you can bend the port easily for the necessary port length you'll need to achieve that tuning.
Here's a new box using the same dimensions that would most likely sound a lot better
1479729_589988074390269_225197132_n.jpg?
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
Okay let me put together something new. Hang tight.
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
Fixed mistake on info, whats anyones thought on changing these ports out to 6" until i can build a new box this spring.
6" aeros would need to be significantly longer just to get the same tuning and you need to tune lower which would make them even longer. I don't think you will be able to fit them in the box. Time for a whole new box unfortunately.
Builds:
I really suggest doing a slot port. Shorted the depth because I figured you have a specific width and height that you prefer.
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
Thank you for your input, i guess new box time. Thats cool though, give me something to build this spring, I wonder if i have enough room to do 2 T1s in a blow thru into the cab.
Thank you for the box design and your help. Much appreciated.
  • Who's Online   0 Members, 0 Anonymous, 1274 Guests (See full list)
