oldsoundguy Posted December 5, 2013 Report Posted December 5, 2013 Ok so I have built a new box for my soundqubed hdc 12" subwoofer. I built my first box for my Re audio sex10d4 and just found the center of the front and put the sub there . So I have sub and port on the same side and sub centered from edge of port to the edge of box. So with the new box were is the best place to put the sub? is it right next to the port or farthest away or middle. I want it to face the same direction as the port so I can fire them both up. Thanks for the help. I have been searching and searching and have found so many conflicting results. 80prs Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier Incriminator IA 10.1 Focal PS 130v 5.25 (doors) 4" Faital pro Neo (kick panels) 3" Faital pro Neo and focal tweets( dash) DC Audio level 3 12" custom box designed by joex built by me AGM front, XS 750SE batteries rear DC 180 alt 99 Toyota Tacoma extra cab http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
gally Posted December 5, 2013 Report Posted December 5, 2013 pics? 2010 Chevrolet Cruze Radio --- pioneer mvh-200vbt Front/back --- alpine type s 6.5" Sub Control --- Pac LC1 Sub Amp --- GZPA 1.4K Sub --- GZNW 15XSPL D1 Battery - GZBP 12.2500X
oldsoundguy Posted December 5, 2013 Author Report Posted December 5, 2013 I don't have any pics yet. I just built the box last weekend and haven't cut the hole for the sub. Its just your basic L shaped port. Its 3 " wide. 80prs Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier Incriminator IA 10.1 Focal PS 130v 5.25 (doors) 4" Faital pro Neo (kick panels) 3" Faital pro Neo and focal tweets( dash) DC Audio level 3 12" custom box designed by joex built by me AGM front, XS 750SE batteries rear DC 180 alt 99 Toyota Tacoma extra cab http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
oldsoundguy Posted December 5, 2013 Author Report Posted December 5, 2013 Ok here are a couple of pics 80prs Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier Incriminator IA 10.1 Focal PS 130v 5.25 (doors) 4" Faital pro Neo (kick panels) 3" Faital pro Neo and focal tweets( dash) DC Audio level 3 12" custom box designed by joex built by me AGM front, XS 750SE batteries rear DC 180 alt 99 Toyota Tacoma extra cab http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
oldsoundguy Posted December 5, 2013 Author Report Posted December 5, 2013 Double post 80prs Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier Incriminator IA 10.1 Focal PS 130v 5.25 (doors) 4" Faital pro Neo (kick panels) 3" Faital pro Neo and focal tweets( dash) DC Audio level 3 12" custom box designed by joex built by me AGM front, XS 750SE batteries rear DC 180 alt 99 Toyota Tacoma extra cab http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
CleanSierra Posted December 5, 2013 Report Posted December 5, 2013 Where you have the circle drawn and placed on the box is the correct way. Get it as far away from the port opening as you can Im not the one you want to try to troll. Just a fyi for you.
oldsoundguy Posted December 5, 2013 Author Report Posted December 5, 2013 Where you have the circle drawn and placed on the box is the correct way. Get it as far away from the port opening as you can So when you say port opening its the one inside the box correct? I get it just want to make sure if anyone searches they get it also. Thanks 80prs Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier Incriminator IA 10.1 Focal PS 130v 5.25 (doors) 4" Faital pro Neo (kick panels) 3" Faital pro Neo and focal tweets( dash) DC Audio level 3 12" custom box designed by joex built by me AGM front, XS 750SE batteries rear DC 180 alt 99 Toyota Tacoma extra cab http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
CleanSierra Posted December 5, 2013 Report Posted December 5, 2013 Yes, the port opening on the Inside of the box. You want the sub as far away from that as you can. It's just that way to prevent the sub unloading into the port. Im not the one you want to try to troll. Just a fyi for you.
oldsoundguy Posted December 5, 2013 Author Report Posted December 5, 2013 Yes, the port opening on the Inside of the box. You want the sub as far away from that as you can. It's just that way to prevent the sub unloading into the port. Cool maybe I will put a new front on the box that has the RE sex10D4 and put it as close to the port as I can and see if I can tell a difference. I have MDF left over from the new box. 80prs Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier Incriminator IA 10.1 Focal PS 130v 5.25 (doors) 4" Faital pro Neo (kick panels) 3" Faital pro Neo and focal tweets( dash) DC Audio level 3 12" custom box designed by joex built by me AGM front, XS 750SE batteries rear DC 180 alt 99 Toyota Tacoma extra cab http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
