Soccerballzs Posted December 6, 2013 Report Posted December 6, 2013 You said you only wanted to do it once. OFC!! http://www.stevemeadedesigns.com/board/garage/vehicle/2438-jeep-commander/I Pioneer P99RSAmpere 38002-Ampere 125/44-6.5 inch Hertz HSK XL Mids4-8 inch JL Audio ZR Midwoofer 2-5.25 Satori Mids2-Morel Tweeters, 2 Hertz Milles 3 inch on A pillars2-Hertz Silk tweeters DC Audio Level 5/12 Skyhigh Wire Mechman 320 XS Power D3100MO Funniest Thread of the Year 2013: http://www.stevemead...dy-being-a-pos/
775Tundra Posted December 6, 2013 Report Posted December 6, 2013 ofc. is it really worth it for speaker wire? you still have power running through it. 2003 Tahoe dc 7.5k dc level 5 15's (3) MMats 341's xs power batts lots of sky high cable dual alts(came off the sky-high gmc and don't know who made them) ipad in center console vu-din in center console all being ripped out and being sold
CodyHendo Posted December 6, 2013 Author Report Posted December 6, 2013 You said you only wanted to do it once. OFC!! damn i did didn't i… hahahaha got me. So 8 gauge all the way around? will that be fine for that much power? and also, how can i connect them all together? if that makes sense. I mean because clearly two sets of 8 gauge sky high won't be fitting in the terminals of the vvxs, so what should i do? lol
CodyHendo Posted December 6, 2013 Author Report Posted December 6, 2013 ofc. is it really worth it for speaker wire? you still have power running through it. very true...
alaskanzx5 Posted December 6, 2013 Report Posted December 6, 2013 Maybe 12 gauge from sub to sub then 8 gauge to the amp? Or 8 gauge but solder the ends together ti make them fit better t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
tacomaguy1 Posted December 6, 2013 Report Posted December 6, 2013 leads coming off the subs with ring terminals bolt in the side of the box sub leads on the inside of the box on the bolt, wire going to amp on the bolt on the outside of the box 2 bolts obviously lol 8+ and 8- Team Flex Issues
CodyHendo Posted December 6, 2013 Author Report Posted December 6, 2013 leads coming off the subs with ring terminals bolt in the side of the box sub leads on the inside of the box on the bolt, wire going to amp on the bolt on the outside of the box 2 bolts obviously lol 8+ and 8- okay that makes sense definitely. So just one positive and one negative bolt? All 8 positive going to the one and all 8 negative to the other? I can't remember if that is how to get a final 1 ohm
tacomaguy1 Posted December 6, 2013 Report Posted December 6, 2013 series them individually, then parallel together so yeah. Each sub will have a positive and negative coming off it. All + to one, and all - to one Team Flex Issues
CodyHendo Posted December 6, 2013 Author Report Posted December 6, 2013 series them individually, then parallel together so yeah. Each sub will have a positive and negative coming off it. All + to one, and all - to one okay so one neg connected to one pos on each sub, and then all those positives to one bolt and all the negatives to the other bolt? sounds good. And that will give the final load of 1. perfect.
CodyHendo Posted December 6, 2013 Author Report Posted December 6, 2013 series them individually, then parallel together so yeah. Each sub will have a positive and negative coming off it. All + to one, and all - to one since i already have ya here… how should i wire up a battery bank? Positive AND negative runs from the front batt/alt, or positive runs from the front, and then ground it off the batts in the back?
