Slammin sonoma Posted December 6, 2013 Author Report Posted December 6, 2013 Then I don't know what to tell you. If anything do the external port up in te canter of the box if its a wall type build and i seal it but port it in the trunk would that work or would it affect loudness ill post a pic mercury milan 1x SA-15 1x db Drive 1000.1d 1x db Drive 80.4 nexus 7 in dash fosgate in doors and deck Id imagine youd get alot of help if you posted in the right section
ToNasty Posted December 6, 2013 Report Posted December 6, 2013 I need a picture. I'm thinking you have a Sonoma because if your username ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
Slammin sonoma Posted December 6, 2013 Author Report Posted December 6, 2013 I need a picture. I'm thinking you have a Sonoma because if your username yes i made this acc when i had a sonoma the big circle is port mercury milan 1x SA-15 1x db Drive 1000.1d 1x db Drive 80.4 nexus 7 in dash fosgate in doors and deck Id imagine youd get alot of help if you posted in the right section
ToNasty Posted December 6, 2013 Report Posted December 6, 2013 Is this an enclosure you already have made? ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
Slammin sonoma Posted December 6, 2013 Author Report Posted December 6, 2013 not made its all in blueprint stage right now im trying to get everything perfect for when im ready to build Is this an enclosure you already have made? mercury milan 1x SA-15 1x db Drive 1000.1d 1x db Drive 80.4 nexus 7 in dash fosgate in doors and deck Id imagine youd get alot of help if you posted in the right section
ToNasty Posted December 6, 2013 Report Posted December 6, 2013 This is tough to say. What ohm are the subs? Your running 6 so that amp might not be able to run with the 6 ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
Slammin sonoma Posted December 6, 2013 Author Report Posted December 6, 2013 This is tough to say. What ohm are the subs? Your running 6 so that amp might not be able to run with the 6 im running 6 dual 4 ive got it worked out to wire it to 1.3 ohms final load (i know about box rise) mercury milan 1x SA-15 1x db Drive 1000.1d 1x db Drive 80.4 nexus 7 in dash fosgate in doors and deck Id imagine youd get alot of help if you posted in the right section
ToNasty Posted December 6, 2013 Report Posted December 6, 2013 I would think about designing a differant box. Make it bigger. Making the box bigger will shorten up the port ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
Slammin sonoma Posted December 6, 2013 Author Report Posted December 6, 2013 I would think about designing a differant box. Make it bigger. Making the box bigger will shorten up the port any bigger and it wont fit in the trunk! mercury milan 1x SA-15 1x db Drive 1000.1d 1x db Drive 80.4 nexus 7 in dash fosgate in doors and deck Id imagine youd get alot of help if you posted in the right section
ToNasty Posted December 6, 2013 Report Posted December 6, 2013 I call bullshit. I've fit more behind a regular cab truck seat ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
