PORTS! and new Build!
okay so i was initially putting a sa-15 on 1k in my milan (which i did) but im starting a new build in like 3 months and seem to keep raising the question where should my ports be? well let me explain the build.....ok so the build is 6 sundown eV.3 8" subs on a rubicon 2500.1d ive researched electrical and found out that with my 150a alt and an xs d925 i can more then supply the power so with that being said im buying 2/0 ga wire to do the big 3 (overkill?) i have located 2/0 to 1/0 reducers from shca....box will be posted below....so the box is going to be a wall type build pretty much walled off directly behind the rear seats (60/40 split) my question is should i fire my ports up (towards the trunk) forward (towards the cab) or back (towards the rear bumper)
mercury milan
1x SA-15
1x db Drive 1000.1d
1x db Drive 80.4
nexus 7 in dash
fosgate in doors and deck
Id imagine youd get alot of help if you posted in the right section
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Is this 2 4" ports for 6 8"s?
this is 2 4"x10"L i want more but i need ungodly port length to get the tuning lower
i do apologize i wasnt paying attention
mercury milan
1x SA-15
1x db Drive 1000.1d
1x db Drive 80.4
nexus 7 in dash
2 - 4" ports will be woefully inadequate for 6 - 8" subs.
Builds:
Your going to need a lot more port area than that. I've had the sa8s. A 3" aero wasn't enough for a single sub. A 4 worked great. I would do 2 6" aeros
thanks for the input the main question i have is which way would be a good way to fire them??
mercury milan
1x SA-15
1x db Drive 1000.1d
1x db Drive 80.4
nexus 7 in dash
How big is the enclosure?
gross is 4.14
is 6 3"dia x 15L a good amount ?
mercury milan
1x SA-15
1x db Drive 1000.1d
1x db Drive 80.4
nexus 7 in dash
  • Who's Online   0 Members, 0 Anonymous, 6112 Guests (See full list)
