Crimping or soldering terminals?
If you have the add on teeth for the vise, then it becomes a crimper. But why not do both? Crimp and solder.
It's impossible to do both.
Soldering is joining the metals together.
Crimping is cold welding the wire and terminal to one.
If you can do both, your are doing it wrong
What the hell you mean impossible. You crimp it then solder it.
truthsayer
What do you mean what do I mean? If you crimp something the proper way, it becomes one piece. It's like trying to solder a copper bar. There is nothing left to solder.
If you can still solder it after your "crimp" then you aren't crimping at all. You are mashing/squeezing/crushing. It's a waste of time
Snow not trying to turn this into an argument, but no matter how well you crimp it does not become one piece. There is still always a small void. Just like stranded cable, no matter how tightly its been wound there is always a void. I imagine if some old timers chime in they will agree with my statement.
truthsayer
riiiiiiiiiiiiiiiiight. Obviously you have not seen a proper crimp in your life then.
What void are you talking about? please elaborate.
Started with a dremmel tool and cutting wheel. I have seen pics of a cut open crimp before and wanted to make sure the heat generated wasn't causing the wires to fuse so I finished with a hack saw
Blury pic, but got about 1/3 through it with the dremmel before switching to the saw
The smoother part is what the dremmel tool cut. The part with the horizontal lines is from the saw motion.
So this is clearly 1 solid piece of copper now. I still wasn't convinced that the cutting wasn't contributing in some way to the illusion of the strands being fused together. Here is a close up... pretty obvious what was done by the dremmel and what was done by the saw blade.
I decided to cut again, a little closer to the beginning of the lug in hopes to see the strands on one side, and them fused together on the other. Got real lucky with the placement of this cut
Send me a piece of cable and I'll throw and end on it so you can see for yourself. It becomes a 100% solid, water tight, air tight piece. Being air tight or "gas tight" is a sign of a good crimp.
Not sure where you are going with the old timers statement. Times have changed, technology has changed. What is available to consumers has changed. We have great tools now, available to the general public that these "old timers" couldn't have dreamed of.
rockFord_Expedition, on 29 Oct 2013 - 3:06 PM, said:snapback.png
Look at the top part of the picture where the crimp meets plastic, thats solder my friend. You can also tell by the cut it has been solderd. Have you ever seen copper look silver.
truthsayer
You're going to make me go digging through my photobucket aren't you
  • Who's Online   0 Members, 0 Anonymous, 1854 Guests (See full list)
