looking into making a box
since my friends in my area and on this forums saying my box is small i guess i should look into making a new box for the summer.
only thing is i have no clue how to make a big box. i have 2 type R's 10's 2 ohm 1000 rms 3000 peak each and i like to place them in there own box. yeah sounds dumb but i like it that way. cost more i know but w/e.
anyways is there any sites that can give me ideas on how to do this my self. don't mine working this out now so by summer it will be ready.
my question is when you place your sub in a 1.0 cubic foot box would it not be less since the sub is now it the box? so it be like .8ish in a way?
Also if you port it the box will be even smaller because you need to calculate port displacement to.
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
Mounting Depth: 195 mm (7.7'')
Mounting Diameter: 275 mm (10.9'')
Displacement: 0.071 cu. ft (Front Mount)
Added Volume: 0.085 cu. ft. (Reverse Mount, Magnet Out)
141 on music.
this is awesome info man thanks. you know any good sites to get the build going?
this website, check out the torres box calculator. How much space do you have to work with? Plenty of guys here can tell you what the right box size and port size are for your application pretty quickly. welcome to the forums!
masterbation is free, and even saves you money.sorry but someone had to say it
sorry, Jimmy...beat you to it (no pun intended)
LOLDON'T get a wife. Best advice I never got, and now it's too late <_<
My build: 12" DCON in a dorm room.
New/current build: 8" woofer, custom amplifier block, fiberglassed speaker pods
um well I have room for like 10+ subs in ported box if i wanted so.... :) and im only working with 2 :D
is it true if you make your sub box longer it will get a little louder kind of like a tunnel effect when you yell in it and its a lot louder?
  • Who's Online   1 Member, 0 Anonymous, 5805 Guests (See full list)
