Can u all help me troubleshoot my problem.
I had a 3001d do this and I never figured it out. Good luck sir
MY BUILD
1998 Ford Explorer 2dr sport
1/0 Big 3 1/0 everything
Alpine cda-9884
Crescendo CZ components
(2) Crescendo bc2000's
(2) Jolt 150ah
(2) Yellow top optimas
(1) Juicebox black cherry addition
(1) Mechman 270 avbm
miss my bc5500 and (4) 15's
You know why people are ass holes online but not in person? Because getting punched in the mouth hurts.
Well I have a other sub u will to on the amp tomorrow and see if it still does it.
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
Back the gain off a smidge and see if this doesn't resolve your issue.
truthsayer
And if it still does it then I will hook up a new amp and see what that does.
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
I will try that but it's like 1/4 way on as it is. My HU has 5v pre out so it don't need to go up far at all
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Would check that your grounding point is on there strong. I have seen wires slip out of crimps and cause this issue as well so i'd be sure to give everything a good tug and make sure it's good. Since you have a meter I would compare your voltage from the front battery to that of the voltage on the amp itself as you shouldn't see much over a few tenths if any drop. Most of the voltage drop comes from a bad ground. To measure ground you choose ohms and touch both probes and record what it reads then you touch one end of the probe to your ground on the amp itself then one on where it's grounded to chassis. Now subtract the reading you had when touching the probes. If it is anything greater than .02-06 then look into a better ground. Make sure to wiggle while testing the ground as well as sometimes a loose wire won't reveal itself until you try to pull through it.
Thanks for the info, I will do what you say tomorrow. And Check all the wires. Only other thing I can think of is that I have my remote wire off my (red) switch wire on the HU, think it could be dropping from 12v and making the amp turn on and off?
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
While I have seen more crazy things happen. I have my doubts on this since the amp wouldn't pull power any differently than it did in the past if you've had it wired this way the entire time. The only thing this keeps telling me is to check spots that tend to be rattled loose by bass cause if it were anything else then you would have noticed much earlier.
Right on, I'm going to just have to hook it back up and get the meter out and see my volt drop and check wires it looks like. Man I hate problems...
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Just went out quick and took a look at the ground. And it was a but lose. So I moved it over a few inches and put it back in. Now it don't move at all. Hope that does it
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
  • Who's Online   0 Members, 0 Anonymous, 3102 Guests (See full list)
