i have no f-in idea whats going on...
Psykotyk
Ok so i installed 4 soundtream 6.5 component speakers in my 2006 ford escape.. i have them powered by a soundstream tx4.440, which is putting out 70 rms per channel at 4 ohm. The speaker systems are 80 rms at 4 ohm so i figured them only being 10 rms underpowered wouldn't make that much difference in volume but they are ALOT quieter than my stock speakers were.. when i turn it up to around 29 (deck goes to 35) my speakers shut off but my amp isn't in protect mode. so could this be my amp is shit? speakers are shit? bad rcas? bad grounds? if your confused please be penitence and i'll try and make things clearer... cheers
Check ALL grounds first. Next check for a pinched wire, like a speaker or remote wire. You may have a piece of wire pinched and the wire exposed to the metal on the car.
Try that first before swapping RCAs .How was the gain on the amp set?
And you have each speaker to its own terminal on the amp right? You're using the xovers that came with them I assume and you're running a positive and negative to each xover from the amp right. Like each xover is getting a corresponding channel on the amp?
Are you using crossovers that were supplied with speaker!? If you are they may have built in protection for overpowering. When you turn volume down do they play again?
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
Did it have a premium sound system in it prior to the new install?
Proper door treatment goes a long way in helping you to get the most out of your components in the quality and output in how well they'll sound.
Honestly though 70w is not a lot of power for comps, look into getting something along the lines of 125w and up, cause once you start getting some power in a sub stage they'll be over powered in a hurry.
Welcome to car audio where upgrading can be downgrading when you don't know what you have installed from the factory.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
yea when i'm using the crossovers that came with the speakers.. and yup they start playing again when i turn it down.. i just dont understand how 4 25rms speakers running off the 18 rms amp in my deck can be louder than what i installed now haha
  • Who's Online   0 Members, 0 Anonymous, 1473 Guests (See full list)
