Joe X Posted December 15, 2013 Report Posted December 15, 2013 Ok, now i'm sure i go with 2 RF 12". I don't really understand what is in blue circle and Red circle. If i understand, The front port width and inside port width is always same size ? I changed my last post so that hopefully is easier to understand and address your questions.
FreeZzy Posted December 15, 2013 Author Report Posted December 15, 2013 Ok thank you, I try to understand ... But now I go to work. Thank you for your helping, I tell you soon if I understand all that ... Just a question, you advise me to make box with port in center or port in left or right ?
Joe X Posted December 15, 2013 Report Posted December 15, 2013 You can do either one, the port in the middle is worry free from potential unloading issues, with the side port box I left you above I wouldn't expect any significant problems.
FreeZzy Posted December 15, 2013 Author Report Posted December 15, 2013 Ok, but if you think it's better with port in center I do like that. I want the box with this size because the subs are 12" (30.5cm) and i want to do lowest height and width as possible. 13.77" (350mm) Height, 30.31" (770mm) width, port 3.14" (80mm) I still don't understand how works the port size on Torres program :s ... and same what is displacements "woofer " " bracing " where you see these measures ? :s Here is picture of what i want for size of box, and in red circle i don't know ... i want arround 30hz with 4.05 cubic feet
FreeZzy Posted December 15, 2013 Author Report Posted December 15, 2013 Joe X i want to send you a message but it's not working ... I want send you that __________________________ Hi; again thank you for your help i don't want to take all your time, i just want to know if is possible to you you make Torres and the design of box with size of each plate and other things ? Because i don't understand how to read port length in torres... Also if you can use dimension of front plate like this: -Height: 13,77" -Width: 30,31" -Port Width: 3.15" (80mm) -And for depth of box you make what you think it's better. I just want the box is tuned at 28 to 30hz if you think it's good or is better more than that ? And more than 4 cubic feet because one sub need 2 cubic feet right ?
Guest Posted December 15, 2013 Report Posted December 15, 2013 the box external dimensions need to be way bigger. the way you have it now is only 3 cubic feet TOTAL. you need to be at like 4.5 to 5 cubic feet, in order to get close to the 4 cubic feet you need after the port, subs, and bracing take up the space.
FreeZzy Posted December 15, 2013 Author Report Posted December 15, 2013 I use same dimension like picture of my first torres of this page, but i use milimeters and not Inch, and in picture with milimeters they show 114 liters, that mean 4 cubic feet ... so my dimension are good. Torres don't show more than 3 feet because i don't put all information and size in program ... look first torres pic on top of this page
Guest Posted December 15, 2013 Report Posted December 15, 2013 what are you maximum dimensions that you can use
FreeZzy Posted December 15, 2013 Author Report Posted December 15, 2013 Dimensions i want to use is:~13.58" (345mm) height ~27.16" (690mm) width "or more if the depth is too much depth, limite of width is 30.31" (770mm) " ~........." (...........) Depth ~12.16" (309mm) Port height ~3.15" (80mm) Port width ~........." (.....mm) Port depth Cubic feet= more than 4 because for one sub Rockford say 2 cubic feet Hz= arround 30Hz ( if you think more is better so i'll do more, but i like low frequency ) Tickness is 0.71" (18mm) ET VOILA I would appreciate if you could do it for me on Torres and Sketchup Thank you
