How will my electrical hold up?
If it were me, I'd give it a go but keep an eye on the voltage. I you start dropping below 12 get a second bat. My bro is running his AQ2200 off a stock 130 amp alt and two yellow tops with knu 1/0 through out, he never drops below 12.9.
It's like rubbing your wiener up against a sheep.
Yes I meant agm and wet cell.
05 Escape
2 Ascendant Audiio Mayhem 15s dual 1
Populus Audio 6500 (the only one around )
1/0 SHCA OFC
XS 3400 under the Hood
XS 3100s in the rear X2
Pioneer 80 Prs
Pac
Prv mids and highs
2 8s per door 1 tweet
What would be considered a safe voltage to drop to? Besides I don't plan on running full blown power 24/7. Also, is it absolutely a no no to mix an AGM (Type 31) battery in the back with my LeadAcid battery up front?
I refuse to drop under resting.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
I did some digging on mixing bat types and from what I could find is worst case you will kill your lead acid, you will over time lower the resting voltage of the agms to that of the lead acid. Thats what I found, could be wrong though, but I'm currently running mixed types but my agms rest only .2 higher than my lead acid so the drop is'nt my biggest worry. I know I will kill my lead acid at some point but so far I have no issues.
Thats me, it might not work for you.
Battery resting voltage
LMFAO so true
:blush:
  • Who's Online   0 Members, 0 Anonymous, 3448 Guests (See full list)
