How will my electrical hold up?
I am planning on running 2K rms. I have a 100A stock alt, 950A cold crank battery under the hood. I plan on performing the Big 3 asap. Well I be able to run 2k (+my sick door speakers) or what will I need to do?
What 2k amp do you have? If you dont mind me asking. ....
2003 silverado TEAM DC
Pioneer Avh 5500
4 DC lvl 5 18s
12 crescendo pwx 6.5s
4 crescendo ft1 tweets
6xs d3400s
Singer 400 alt
Skyhigh ofc wires
Skyhigh speaker wires
Smd vm1
2 DC 175.4
DC 10k
for 2krms, i would make sure you have a nice sized AGM up front, and a group 31 AGM in the rear as a second battery. That and the big 3 and you will be fine.
I know people want to know the amp to say if it can really pull close to 200a (rated power), but i feel like it is going to end up in a "well you should upgrade to this amp" type of thread.
my .02
Im getting an Alpine MRX2000 from a friend. Its a good amp. It'll be ppowering two SA12s. Would a big normal lead acid battery upfront be fine? I wouldnt mind upgrading but ive got 2 years on my warranty for it still.
my .02
I agree, and thats what I was going to bring up, op how much are you buying the alpine amp for? Is it around the same price as a sa amp? Just my .02 check out the for sale section around here to see if you may be able to find something around the same price that will put out rated, and to get back to your question if you want to run 2k watts - big 3, agm batt, and I would recommend an h/o alt unless you can find an amp that likes to run under 14.4v maybe some one else can chime in
Pioneer Avh 5500
4 DC lvl 5 18s
6xs d3400s
Singer 400 alt
Skyhigh ofc wires
Smd vm1
2 DC 175.4
DC 10k
it should, be watch your voltage drop and make sure the cells are filled correctly not too much not too little
as for when you upgrade i suggest xspower or odyssey
make sure you got good grounds no paint/primer clean metal surface and if you got a dinky lead coming off the alt make it bigger if you can
skar sk2500.1
0 gauge power and ground kunukonceptz
alpine HU
vxi65 components on BA gt-275
new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821
2 x-15 sundowns
singer alt, odyssey bat, and maxwell ultra caps
I second the H.O. alt. It just better than to try and compensate with batteries IMO.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
I would love an HO alt, but to get good quality one you're looking at at $500. My truck has 240k on her so who knows how much longer she'll last.
I've seen people run2k or a little more off of a good under the good battery and a good battery for the amp with smaller alts. I was just wanting to get your guys opinion.
As for the price,I'm paying 315 shipped. It's a year old but with only 6 months use by guy who knows his stuff so he likely didn't do much harm to it
  • Who's Online   0 Members, 0 Anonymous, 3374 Guests (See full list)
