SA-8 35 Hz tuning question
the torres tuning calculator isn't working properly. the port tuning frequency is telling me all sorts of odd numbers. its telling me a port 10.5 H x 2.5 W x 24 L = 44.58 Hz with a box that has 1.91 gross volume. If I increase the length by 10 inches then it only drops less than one hertz, if i increase it by 20 inches then it bumps up to 53 hz. How the heck is this possible? But when the length is set to 15 inches the tuning frequency is 49 Hz. Its like theres no correlation between length and tuning frequency with this calculator
09 Challenger R/T (Audio system under construction):
  • Pioneer AVH-X4500BT (PAC RP4CH11 harness)
  • (2) Sundown Audio SA-8v2 (inverted)
  • CT Sounds AT1400.1D
  • XS Power D3400
  • 40 sq ft. Audiotechnix deadener
  • 1/0 Audiotechnix wiring
  • stock Boston Acoustic 7 speaker amplified system (for now)
  • Sealed trunk enclosure
Build log:
http://www.stevemeadedesigns.com/board/topic/178399-slammed-dodge-challenger-sundownct-sounds-build/
TEAM GOAT
my understanding is that the tuning should lower with increasing length but with this calculator it doesn't follow that rule at all. it moves all around
  • XS Power D3400
Build log:
TEAM GOAT
you dont care about gross volume you care about net volume
don't you use the gross volume to calculate the net volume by accounting for the displacement of the port??
  • XS Power D3400
Build log:
TEAM GOAT
well i have an internal volume of 1.91 cubic feet. I will be running the subs inverted. The port dimensions I have right now are 10.5 x 2.5x 25.94 which is supposed to be 35 Hz. The port displacement is a total of .39 cubic feet. So my net volume of my box will be at 1.52 cubic feet. Hows this sound?
  • XS Power D3400
Build log:
TEAM GOAT
  • Who's Online   1 Member, 0 Anonymous, 780 Guests (See full list)
