Im building a box for 2 SA-8 v2s to 2.19 cubic feet. I want it tuned to 35 hz. How should I build the port? I was thinking 2.5" wide and 10.5 tall. Might this be too big? Id have to make it 24.25" long to tune to 35 hz with it 2.5" wide. But since the port will be in the middle when it splits in opposite directions it will have to be 1.25" wide which seems really narrow. What are your thoughts? should it be wider?
09 Challenger R/T (Audio system under construction):
  • Pioneer AVH-X4500BT (PAC RP4CH11 harness)
  • (2) Sundown Audio SA-8v2 (inverted)
  • CT Sounds AT1400.1D
  • XS Power D3400
  • 40 sq ft. Audiotechnix deadener
  • 1/0 Audiotechnix wiring
  • stock Boston Acoustic 7 speaker amplified system (for now)
  • Sealed trunk enclosure
Build log:
http://www.stevemeadedesigns.com/board/topic/178399-slammed-dodge-challenger-sundownct-sounds-build/
TEAM GOAT
How about 18" of 4" aero port with on 1.5 cubes.
I litterally just built a box for 2 sa v2 8s today for my jetta. The box is 40 wide, 10 tall and 12 wide. Port is 2x8.5 and is 22 inches long. I will be putting a saz1200 on it in the next few days. They are currently on a the 2 rear channels of a 100.4 and are getting down on low power.
formerly known as Blue86f150
this sux camel dicks
2.19 gross. The displacement of the port should bring it to the recommended 1.5 net right?
  • XS Power D3400
Build log:
TEAM GOAT
ok well maybe 2.19 is a tad high for gross. but I'm assuming the gross should be somewhere around 1.9 to 2 cubic feet so with the port taken into account the net volume will be around 1.5-1.6 cubic feet which is where it needs to be. the question is with it being tuned to 35 hz is 2.5 wide by 10.5 tall an okay size port? I just feel like when the port splits into two opposite sides that a port only 1.25" wide seems small
  • XS Power D3400
Build log:
TEAM GOAT
  • Who's Online   0 Members, 0 Anonymous, 1747 Guests (See full list)
