Bump4life Posted December 18, 2013 Report Share Posted December 18, 2013 if its one speaker check the negative on the speaker wire all the way through. if the insulation has worn through and it is touching metal that can cuase a groun loop and cause that speaker ti whine. Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick Link to comment Share on other sites More sharing options...
TS2GFrank Posted December 18, 2013 Author Report Share Posted December 18, 2013 Found the problem guys....turns out both sets of my RCAs are shot. When I switched RCAs I only swapped the front set with the rear set. Before I tried the grounding method you advised me I figured I should maybe try a new set of RCAs instead of a different set before I start ripping my HU and amp out. I had a unused set waiting for when I re-install my 3Sixty.2. Plugged them in and crystal clear music came through with no feedback. I still don't know how both sets only caused feedback through that one speaker but no others. Thanks for your advice anyway guys Link to comment Share on other sites More sharing options...
Tarball Posted December 19, 2013 Report Share Posted December 19, 2013 Do yourself a favor and ground your RCAs to your deck while you are working on it. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db Link to comment Share on other sites More sharing options...
