Amp for DC Audio XL 12"
02Explorer
sound Qubed 2200D 429$ 2200w rms at 1ohm
ct sounds 2500.1D 775$ 2500w rms at 1 ohm
Alpine MRX M240 420$ 2400w rms at 1ohm
all at <1% THD all will do more than rated
Good Luck
Subs= SoundQubed HDC3.112 Amps= Audio Technix1200.1, Sony XM4x40 & Clarion XC1410 Rear= Pioneer 6"x9" coaxial Front= Polk 6 1/4 componants Trunk Lid= Pioneer 6 1/4 coaxil Battery= Optima Yellow-top (front) Shrunken 35AH Wire= 0/2 AWG welding Cable! Alternator= 125amps Extra= Continuous duty solenoid
I'm going to go with an RF T2500, I have the same setup one XL12. But I'm kinda bias cause I have run RF for a long time.
Yes that is a great amp as well however at 1,200$ its the most expensive amp of the bunch for being in the same "quality range" as the others mentioned
You stated amp for XL12, correct? I saw nothing about price. If price is an issue for you it"s SQ2200 all the way end thread.
spelled it's wrong lulz.
Your right was just explaining my thought process. not allot of people have 1200 to dish out on an amp tho
Good Luck
yeah but CT sounds amplifiers are rated at 12,8V,,,instead the other two amps are rated at 14.4V which you will rarely see a 14.4..
other than that CT should put wayy more power...
2010 Chevrolet Cruze
Radio --- pioneer mvh-200vbt
Front/back --- alpine type s 6.5"
Sub Control --- Pac LC1
Sub Amp --- GZPA 1.4K
Sub --- GZNW 15XSPL D1
Battery - GZBP 12.2500X
The ct sounds 2500 did 5000 watts on the amp dyno at 12.8 so that should be out of the question
06 monte carlo
2 12 rockford p3s
soundstream rubicon 2500
crescendo audio mezzo 6.5
ct sounds 125.4
execution audio and shca wiring
2 xs d3400 on stock alt
That CT Sounds 2500 was doing over 3K at 12.? volts.. Ill try and find the vid
Edit: 3923 watts at 12.74v certified run on the amp dyno
Thats cool. Im way too old to be upset by shit like that. Your name is winston. Your own parents hated you even before you were born.
My penis is bigger than your penis
I'm far from loud and my roof/headliner flaps around like Adam's ass on a windy day. I think it depends more on the structure of the vehicle.
  • Who's Online   0 Members, 0 Anonymous, 683 Guests (See full list)
