how much volume should a port have?
GueroZ28
yeah, it does seem that way.
I was saying thanks though because I mentioned it and then saw a post saying port volume is important when its the area and not the volume that matters.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
What was said is that port volume is important to the total volume of the box but not tuning. I said that after saying at the beginning of the thread that port volume is irrelevant to tuning. ;-)
Facebook: facebook.com/audioanarchyllc
Instagram: audioanarchyllc
Youtube: youtube.com/bbeljefe
If you just want to calculate yourself the box download Torres calculator and read the manual inside, it will calculate everything for you just make sure to give enough port area, the manual tells you how to give enough port area.
Im still using everything the same just a bit smaller since im now using h the 1/2mdf but everything still seems the same to the calculations u gave me (i think it was u)
Ok I checked your older thread, listen, if you want to understand for yourself how all this works you need to study. A ported enclosure operation is defined by 3 variables which are NET internal volume, port tuning and port area. Port volume does not define anything regarding the operation of the enclosure, it just happens that if the port is larger in size your box will be also larger in size.
Thanks thats what i was looking for.. and i was getting confused mainly because i have no idea how to exactly explain what my question is.. only question now is does each sub hqve a different recommended port area or that depends on the tuning and the box internal volume?
  • Who's Online   0 Members, 0 Anonymous, 6313 Guests (See full list)
