2007 tahoe electrical
hey guys i have a 2007 chevy tahoe im trying to figure out what i need to do for my system to sit at about 13 volts at full volume. right now i have 4 crescendo 8pwx and 4 ft1 tweets on 1 kicker zx850.2 on 8s and kicker zx 850.4 on teewts. for bass i have 2 treo ssx 18s on 1 mmats 3000.05d(plan on doing a bigger amp soon). now for electrical i only have a stock 165amp alt, 1 run of 1/0 from from batteries to rear batteries. big 3 is done and for batteries i have a regular advance auto gold battery rated for the truck and a kinetik hc 1800in back i have 2 kinetik hc2000. at full tilt my truck drops to like 11.9 can anyone help
Not much to help with other than get a bigger alt. Or more battaries. That voltage drop isn't that bad either
06 monte carlo
2 12 rockford p3s
soundstream rubicon 2500
crescendo audio mezzo 6.5
ct sounds 125.4
execution audio and shca wiring
2 xs d3400 on stock alt
run another run of 1/0 to the rear. Bigger alt would help a lot. Just make sure you are using quality wire and lots of it (overkill). You have decent amount of batts for what you are running. I would do other things before buying another battery. Add another run, get a bigger alt, then see what your voltage is at? You have an aftermarket volt meter i'm assuming? What did you do for your big 3 with the ground sensor under hood? You factory alt is big because your vehicle prolly requires quite a bit of juice, just cuz it's big doesn't mean it will suffice.
Possibly post up pics.? Wiring can play an important role so don't skimp anywhere.
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
ok ill post pics later. tell me this even if i run another run of 1/0 even with the factory alt would that really help the voltage at all? and what do you think about taking out the advandce battery cause i always heard they dont work as well as having the deep cycle when wired together
Problem with the 2007 Tahoe is that the alternator cycles on and off and sits at around 13.4v factory. I went with DC Power for my alts with an external relay that moved my voltage to 14.7 resting at idle now.
Team Ampere Audio
  • Who's Online   0 Members, 0 Anonymous, 3374 Guests (See full list)
