battery question? might be easy to awsure.
I personally am at a debate of either die hard platinum, kinetic, or xs power. money being the deciding factor. I know xs is a proven brand but ive personally seen builds with the die hard platinums doing fantastic and the kinetic batts have great reviews.
ill have a 250amp singer alt on an external adjustable voltage regulator
2 runs minimum of 0 gauge
big 3 with an alt ground (or 2) to frame
but ill have 200-400amps of power draw between 2 t1500.1bdcp ( 150amp max each guessing closer to 50-75 daily each) and 2 t400.4. (100 max each guessing closer to 30-40 daily each)
when it comes time for me to suck it up and spend money on the batteries my wallet will be the deciding factor but at the same time if there was a way for me to know for sure how it would hold up with just on xs d3100 and it didn't drop below 13v I would go that route but I don't have the money to test that (unless someone near me has one I could put in and go full tilt on for a quick test) so ill most likely leave it to the flip of a coin and hope for the best end result.
buying batteries can be a gamble. you don't know how your choice will end up until you play your hand.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   0 Members, 0 Anonymous, 3448 Guests (See full list)
