battery question? might be easy to awsure.
when I look at lets say XS power and kinetic ( forget the fact one is better then the other here).
I looked at the kinetic 2400.
says it does 2400 watts says 2600 but ill just say 2400 for the hell of it
and 128 amp hours.
and when you look at a smaller battery from
lets look at the xs power D5100
it has way more watts (3100 watts max)
but now this one has less amp hours:60....
little help here?
when I look at this im not even sure whats going on here. for a person who like to lessen to music. would I not want more max output or more amp hours?
with out looking at the fact there both different batterys its the point im looking at is what does the audio person really look at?
I dont really look at the ah, I look more at the output for the reason the ah comes into play when your vehicle isnt running. .. I really dont listen to my system with the truck off... I prefer xs batts but I know kinetic is a good battery as well....
2003 silverado TEAM DC
Pioneer Avh 5500
4 DC lvl 5 18s
12 crescendo pwx 6.5s
4 crescendo ft1 tweets
6xs d3400s
Singer 400 alt
Skyhigh ofc wires
Skyhigh speaker wires
Smd vm1
2 DC 175.4
DC 10k
Ah come into play with the vehicle running if your alt can't keep up on it's own, ah isn't tested all the same, some test at higher loads fire shorter time piteous some at lee loss for longer time periods
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
For me, i only look at amp hours. Amp hour is important, to me, because, like mentioned, when your at and then beyond alternator capacity, your into battery "reserve". Thats why we have banks. And yanking 6-7-800 amps, the alt is maxed preeeeeeeety quick, lol.
so when we are talking about when its on I should be looking at the ah? but when its off I should be looking at the max watts?
the kinetiks are readily available here in canada
the xs have to be brought up from the states
or you can look at dekas which come from the states but they are a bit cheaper..
AH is an important thing to look at but one 128 AH battery isnt going to help much. get a couple. or four. or eight. :twirl:
fisigggg.JPEG?raw=1 Crossfire_Car_Audio2_265_zpsd219cf51.PNG ablogo_zps4c550ed1.PNG?raw=1 download%204_zpsecsgajxi.JPG?raw=1 Audison-Logo_zps3f7b2a7f.JPG?raw=1 sundown_bg2_zps1d0951fc.JPG?raw=1 orionsmalllogosig_zpsf8d08612.PNG?raw=1 KaptionLogo_zps06c2a555.JPG?raw=1
I RREEALLY ANGRY WIT U PHOTOBUCKET. HAD TO USE DROPBOX NOW HOLYYYYYY.
Wanna ride bikes?
Quote
On 9/16/2017 at 3:28 AM, Jake Pace said:
Oh i know how a 12v system works I did take 3 years of electronics in High school hands on and some in college and also worked on cars in college an always got A's to B's in each class.
But oh well enough dealing with ppl who have probably not even lived as long as ive been into electronics!
On 7/8/2013 at 4:01 AM, Banshee421 said:
Do horns get low
not caring about buying batterys just was a little lost when I seen one with more watts less ah and vice versa with the other.
for example say we have 2 batteries, battery A and battery B.
battery A
amp hours at 20 hr rate: 100
amp hours at 10hr rate 92
battery B
only says 110ah
battery b doesn't give good enough details to make a real comparison of the 2. you don't know it that 110ah rate was amp hours at 20 hr rate or at 10 hr rate. to make a real comparison with out doing real world testing you would have to find out more about battery b.
comparing 2 batteries just by their ah isn't exactly possible to do when not all batteries are listing the specs taken the same way. unless you know both are at say a 10 hr rate you cant compare them, its like comparing apples to oranges.
what really matters is real world testing. now no one has money to buy different batteries until they find the one that does best in their car. that is where looking at reviews of batteries and trying to talk to people that have personally used one of the batteries in question. there is a video xs power did load test different brand batteries of the same group size to do a comparison, it does show if im not mistaken the kinetic they tested was fairly close to their battery in the testing they did. im sure if you look hard enough you can find other videos of load tests on different batteries as well.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   0 Members, 0 Anonymous, 3374 Guests (See full list)
