Need a box design for 2 p3 15s rf
Skax
What all do I need to measure to get a box design and if anyone could help me find someone to build the box also it would be great as my local audio shop is charging 250$ for a custom built box.. Car is a 2000 Saturn l series
2002 Mustang GT Procharged
Procharger P1SC Supercharger, 8psi
Procharger Intercooler, Headers,
Borla Off Road X-Pipe Exhaust, Mass Airflow
Upgraded Fuel Injectors
SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Where are you located? Maybe there is a member in your area that will help you out. Also $250 for a box for a pair of 15"s isn't terribly unreasonable.
Builds:
Sylacauga Alabama
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Just imagine a box being where you want it and measure height, width, depth. I'm sure someone here will help.
That Saturn is a sedan right? If so it will be pushing it to fit 2 15" subs.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
correct and ideas?
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
measure from trunk floor to the lowest part of the top of the trunk
measure from wheel well to wheel well
measure from front to back of trunk.
post the measurements here and people will tell you if you can fit 2 15" subs in that area. chances are you cant. most sedans run either a single 15, 2 12, 10's, or 8's. not many sedans can fit a proper ported box for 15's, a sealed box could work though.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   0 Members, 0 Anonymous, 5110 Guests (See full list)
