Noel989 Posted June 16, 2014 Report Posted June 16, 2014 I've already noticed many member pushing upwards to 10K, which I find ridiculous, but at the same time, I'm not into the Comp scene. I know theirs poeple that run 10k+ and don't compete Number of watts is irrelevant to whether you compete or not Build Log - http://www.stevemead...-cruiser-el-pt/
STEvil Posted June 16, 2014 Report Posted June 16, 2014 AGM/Gel Cells are also lead acid batteries. They're actually called valve regulated lead aid (VRLA) batteries and the appreciable differences between them and wet cell lead acid batteries are the facts that they can be mounted in any position other than inverted, they rest at slightly higher voltage and they tend to last longer than wet cells. There is nothing at all unsafe about mixing wet cell and AGM lead acid batteries, nor is there anything particularly unsafe about running wet cell lead acid batteries inside a vehicle's cabin space (the Corvette battery was right behind the driver's seat in the early 70's, iirc). If you do run wet cell lead acid batteries with VRLA lead acid batteries here's what will happen.... when the vehicle is not running, the wet cell lead acid batteries will rob a few tenths of a volt from the surface charge of the valve regulated lead acid batteries. That's it. No explosions. No batteries fighting one another (heard that one recently). No zombie apocalypse. Sorry. I'm sure the last one would be kinda fun. If you hear a hissing sound or smell something funny dont stay in the vehicle if you like your lungs.. MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
