I know mine can be fickle iwth the ground. I eventually just started going to my ground distro block for the ground. once I knew the aligator clamp was a good solid ground I have had no issues with mine at all. Thats why I asked. not just a good ground for the amp but a good ground for the ground clip
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
It seems to be okay. I feel like its an issue with the PAC adapter that is causing the distortion. When I turn the levels all the way down it does not show any signal on Track 1 and if I turn it even a little it distorts, sometimes without showing a signal. I guess I need to test the factory amp and see if my theory is correct.
UPDATE:
It is the PAC adapter. I hooked up the dd1 to my rear 6x9's and play track 1. I was clean all the way up to 32 out of 40.
What are my alternatives to the PAC to send clean signal to my bass amp?
  • Who's Online   0 Members, 0 Anonymous, 607 Guests (See full list)
