Soundqubed hds300 series
JTeas
3-3.5 cubed after port/woofer/bracing displacement should do fine with a tuning around 33-38hz daily with about 40-45sq inches of port.
Ive only messed with the hds 12 so far.
Sadly they dont give box specs on their site, and only a handful of T/S specs (unless it was updated recently).
So you can only really go off their generic box size spread sheet that says you can put one 15, two 12s, or three 10s in a 3cubed box.
I say its generic because they are using these same box specs for their cheap 2.5inch voice coil woofers as their higher power 3inch coil woofers like the hd3 and hd4.
Or you can go by their atrend box recomendations, but yet again another prefab method which is built on the same method.
I will say this i do know sq subs like bigger boxes so i would use the biggest one they say ifbyou can
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
  • Who's Online   0 Members, 0 Anonymous, 5110 Guests (See full list)
