Hard for me to explain but...
Skax
As long as your 0 gauge is your primary power wire then yes, 4 gauge to both amps is fine. A distribution block with a 0 gauge input and 2 4 gauge outputs will work just fine. You can get yourself one like this http://www.sonicelectronix.com/item_15319_e2-EWDB2-by-Scosche.html that is fused for two runs. A 100-150 amp fuse for the 1500 would work and a 50 amp should hold up the 4 channel
i guess my question to is would this be more sufficent than using the capacitor?
If you want more effiency loose the capictor and add a second battery.
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
A distribution block is used to distribute power, a capacitor stores a x amount of energy
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
what i was ganna do is lose the capacitor order a XS-D925 and run 0awg to distribution block and my 2 4awg cables from amp to distribution and ground the 2 amps seperately would that be fine?
2002 Mustang GT Procharged
Procharger P1SC Supercharger, 8psi
Procharger Intercooler, Headers,
Borla Off Road X-Pipe Exhaust, Mass Airflow
Upgraded Fuel Injectors
SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
also what can i put in my dash or somewhere to check my voltage i always checked mine off the capacitor and if i take it out what do i need to get?
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
That will work fine
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
That will work fine
i was told to put the XS-d925 under the hood though since my stock battery is garbage and i was ganna get 2 XS-d3400's when i get the money for my new system
so xs-d925 under hood and what about voltage meter thing? i just wanted a small one to mount under the dash by by bass knob if possible
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
That will work fine
I would run your larger battery under the hood/smaller suplimental batteries in the trunk
oh lawd.
oh lawd.
so instead of getting rid of my stock battery you think i should i should throw it in the trunk? and how can i charge it when it dies or do i wire it to my under the hood battery? and just run wires from one in trunk
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
  • Who's Online   0 Members, 0 Anonymous, 700 Guests (See full list)
