Engine noise fix?
The VFL Line of competition amplifiers are true work horses. The Hybrid series is no exception. Unparalleled power per dollar and a small footprint. Find out why these amps are the choice of pros everywhere!
1 ohm Stable Digital Mono Block
4500 Watts Peak Power
2200 RMS @ 1 Ohm
Bass Knob Included
Variable Bass Boost
Variable Low-Pass Filter
Variable Subsonic Filter
Dimensions: 13.25" x 6.5" x 2.25"
Why is it hard to find info on the american bass amps.
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
Did you ever take te head unit out and make sure all the connections the shop made where correct. Just because a shop did it does not mean its correct or there is something wrong with the head unit
141 on music.
I took it out and make sure the connections were correct but idk man. Its not an engine noise the noise still happens when you pull your key to you and dont engage the engine
Did they use a wiring harness or did they splice it in. Also it could just be something wrong with it strate from kenwood. I learned this along time ago, just because its new does not grantee it to work.
141 on music.
  • Who's Online   0 Members, 0 Anonymous, 3374 Guests (See full list)
