T shaped box?
D-Wake
Does the shape of a box play a huge role in how it will sound? I've built a couple boxes but they all have been smaller square sealed boxes and now I am wanting to step up to a ported box for 2 12's but I have a reg cab silverado. I've seen some boxes with 2 12s in the center console but to get the cubic feet the box is not practical to me so I am thinking of combining a box for subs behind the seat and a center console with the subs firing down in the console and the port coming out the passenger or driver side or whatever is best. Not sure if Im explaining it right so I came up with an extremely rough sketch to show what I'm thinking..
Does anybody think this would work? Or be worth trying? Also port size is a free port size app not sure if it's right just using for an idea
Doing something like this is much better, '03 Sierra single cab so pretty much the same truck.
http://www.stevemeadedesigns.com/board/topic/175080-cleansierras-build-log-fosgate-regular-cab/
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
Yeah that's what I figured but if I'm going to be building a center console at the same time I make a box I just thought it might help get more air space which from what I understand is what you want in a ported box?
You're fine with odd shapes for the box. What you want to avoid (with any vented box) is loading a sub directly into the port or having one sub much closer to the mouth of the port than the other.
As for port area, no one can tell you if what you have is adequate without knowing what subs you're using, what the tuning frequency will be and how much net internal volume you have.
Facebook: facebook.com/audioanarchyllc
Instagram: audioanarchyllc
Youtube: youtube.com/bbeljefe
2-12inch power acoustik mofos 900rms to each
35hz is my goal
Box volume should be right around 4. cubic feet
Ive built a few t shaped boxes and they work great! Just build it extra strong in the areas that join the 2 "boxes" together
35hz is my goal
Your port area should be fine. I'd go maybe to 25in² if you can but if not, that should be okay.
  • Who's Online   1 Member, 0 Anonymous, 1761 Guests (See full list)
