10k amp minimum number of batteries to run
A rep shouldn't tell you that especially since they are probably only warrantied at 1 ohm. I haven't looked to hard into B2 so I could be wrong. I don't see the DC or sundown or CT dealers saying wire at .00000016 ohms for power.
2003 GMC Yukon Denali
Alpine CDA 117
Redoing Mids/Highs
4 Runs of 1/0 Knukonceptz 2+, 2-
4 Deka 9A31's in back (Stock underhood) 250 amp Alt.
AQ20K
2 18" Crossfire XS V.2's 12 cubes 33hz 149sq inches of port!
8 Batts or more period
If you are asking you don't know... which means more Batts
4 is not enough... at all
4 is like me running my 2 750.1s on the 7 Batts I had in my trunk.... it's not enough!!
8 Batts minimum is what u would do
It's clear u can't afford that start with 6 run at 1.5ohms. Good luck
SCSB
Santa Cruz Speaker Box
Build logs:
Daily Driver Lemon Marquis
2 american bass 750.1s
350.4 on 14 focal 6.5s
sq 945 on 4 hertz tweeters
http://www.stevemead...__fromsearch__1
The Mustang 'dubbed' Shirley the project from bullet holes to badass
http://www.stevemead...cond-skin-time/
I'm running 2 nendo 5500s @ 1 ohm each off 5 d3100s, a hc1800 under the hood and a 200 amp alt. I rarely see below 12v. At 1.5 ohms I think you'll be OK with 4 d3100s just keep an eye on your voltage.
4 fully loaded Fi sp4 15's
2 Crescendo bc5500s
Crescendo c1100.4
6 focal mids
Vifa tweets
5 XS Power d3100's
Pioneer avh-p4200dvd
All crammed into a mustang.
http://www.stevemeadedesigns.com/board/topic/150569-mikeg321s-fi-nendo-mustang-getting-walled-videos-page-4/
  • 8 months later...
well I ran at .67 ohms with 4 batteries in the back xs d3100s and one 34 under the hood and a 270 amp alt. from mechman and voltage never dropped below 13.8. now I am running the same set up at .25 ohms and it can't do it daily.. I can do a burp thats it. 155 db outlaw score non wall with 3 DD9515s I am ordering 2 more d3100s this week. hopefully I can run at .25 daily then...
  • Who's Online   0 Members, 0 Anonymous, 1819 Guests (See full list)
