one americanbass 750.1 at .5 ohm or two 750.1s at 1 ohm?
leonfowler
What subs you have? Teams?
yes i have the team subs d2s, im not sure what route to take now lol
2004 Chevy Trailblazer LT
Walled- 10.5 cubes net tuned 33Hz
2-15 inch AA Team subs D2
Americanbass- 750.1
1 yellowtop under the hood , 4 c&d 88ah batteries in rear
mechman-270
pioneer headunit-4200UB
4 soundqubed supertweeters
phoenix gold 2 channel
back up camera
stinger volt meter
22 years old and still have alot to learn..lets get it
Trade my teammate for his d1s then run 2 amps .. An d2s are actually 1.4 an d1s .7
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
I look at it like this @ .35 I have 2.8 ohms of rise which means .98ohms final load at .7 that rise is 1.96ohms so my amps make max power at 1 ohm compared to 2 ohm which in turn doesn't justify raising impediance
Rise? At what frequency/frequencies?
To the op, you probably won't hear a difference.
But the 2 750's should be more powerfull or atleast be easier on the electrical with the same power.
Rise is too .98 from .35 .. Yes it will be easier on electrical why? Cause they won't be making as much power .. Theory says more amps cuts rise in half but I tested it an had .2 gain on meter .2 don't justify $3500 bucks
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
To me one amp at .25 was just as powerful to 2 amps at 1 ohm
Both amps at .25 no comparison much better way more brutal but better have some electrical to back it up
I wouldn't do it again unless I had more Batts or electrical at least equivalent to ray (aahoe) 3 alts and 10 Batts
Minimum would be 2 alts 8 batts
SCSB
Santa Cruz Speaker Box
Build logs:
Daily Driver Lemon Marquis
2 american bass 750.1s
350.4 on 14 focal 6.5s
sq 945 on 4 hertz tweeters
http://www.stevemead...__fromsearch__1
The Mustang 'dubbed' Shirley the project from bullet holes to badass
http://www.stevemead...cond-skin-time/
i would love to trade him ill add alil cash too because he would be helping me out....and thanks ray im glad u tried it out and saw the results ... its funny cuz you would think 2 7ks at 1 ohm would destroy one 7k amp at .5 ..i guess that always isnt true anymore
Americanbass- 750.1
mechman-270
back up camera
stinger volt meter
There is no such thing as rise. There is only a impedance curve, which means some values will be below or above that value.
Also because a amp at 0.5ohm won't be as efficient as a amp at 1 ohm. (or 2 amps in this case)
So on the termlab there should be a gain, except it never is worth it for your "ear-o-meter".
:lol2:
Do you have 2 8ks. Have you ever even considered running 4 8ks?
You should look who you talking about
ray has forgot more knowledge than you have
SCSB
Build logs:
Where are u from? I'll trade I'm going differ route with my build
SCSB
Build logs:
im from los angeles and i heard alot of great things about you and ray ..pm when u can or text me at 818 220 1120
Americanbass- 750.1
mechman-270
back up camera
stinger volt meter
  • Who's Online   1 Member, 0 Anonymous, 645 Guests (See full list)
