Voltage drop.
Been running my system for a few months now without issue. I have all 1/0 power and grounds and big 3. Noticed for the first time today I'm getting like a 1.5V drop at high volume only when bass hits. I have stock battery and alt but I'm only running a total of 750 rms pulling 110A. Think battery or alt may be on the way out?
3bc3a7ec-d90c-40a7-928f-eef8c019b42b_zpswww.facebook.com/EKCASA
System:
All Rockford Fosgate
Front: 2 Pair Prime 6.5's and 1 pair Prime 5.25 Components
Rear: 1 Pair Prime 6.5 3 Ways
Subs: 4 Prime R2D2-12's
Amps:
Front: Prime R250X4
Subs: 2 Prime 500X1d's
HU: JVC KD-AR959BS
2 Optima Yellow Tops
Singer 230A H/O Alt.
Lots of KnuKonceptz 1/0 and accessories
105 Sq ft Kno Knoise deadener
Possibly. Wheres your voltage meter wired to?
Did you check all the obvious things.. like your grounds?
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
1/0 for a rated 700 watts? Damn.
Go big or go home lol
LMFAO so true
:blush:
somethings wrong, my voltage hardly moves with 1k on a 90 amp alt..
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
go get alt and battery load tested.
look for loose connection points in the wire you've added. at the wire lugs (tug on them fairly hard. they shouldn't budge at all). at the input and output of the fuse block. the screws that hold the fuse down (if running an anl/mini anl) or make sure the fuse isn't easy to pull out if using a maxi style fuse. check the ground wire too.
Are connections good. Good ground?
What's the lowest voltage you saw
Check your battery. Also, if you have a regular starter battery and not an agm, it probably just needs a recharging. 700 rms aint shit to an agm but to a regular starter it could be a problem.
Noticed it on the stock voltmeter first then checked the digital on the cap same thing.
Didn't have time to check ground yet but pretty sure they are solid I have lock washers on all the bolts and compression fittings on the fuse and ground blocks.
Yeah 1/0 on 700, but it is CCA and went over so I don't have to do complete rewire when I upgrade.
Over kill never hurts.
All the ring terminals are soldered and rock solid.
Battery is a starter Napa Premium.
System:
Amps:
Front: Prime R250X4
HU: JVC KD-AR959BS
compression fittings? Might be your issue there. regular wire lugs or bust
edit. unless you mean the ones with the Allen wrench screws. I was thinking of the knukonceptz kompression stuff
  • Who's Online   0 Members, 0 Anonymous, 3129 Guests (See full list)
