The rca Jack is nice and tight.
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
Wait, what are you trying to do?
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
80prs
DC 180 alt
I'm trying to measure my HU max volume without distortion first, and never got a signal. So it could be either a bad ground, loose/bad RCA, or speakers not being disconnected first from the HU?
“The fascination of flight can't be expressed with words. But it really lies beyond the capabilities of human endeavor. Once you've experienced it, you'll never be able to forget it.” - Friedrich Oblessor
so you are powering speaker with the headunit?
I have seen this issue and have dealt with it.
The right way is yes, unhook speakers and test the h/u speaker outputs and use the volume from track 1 and 2 as your max and match your amp to that before you hook up your speakers again.
you may end up with the gain all the way up since h/u internal amps are pretty dirty.
Don't use the dd-1 with speakers hooked up. Although you can do it that way you shouldn't.
So I gotta rip my HU out and disconnect the speakers first?
You don't have to but if you don't, you get what you got. And when you're running on head unit power, you should never (in my experience) be at 80% volume. Every head unit amp I've tested distorts at ~60-65%.
Facebook: facebook.com/audioanarchyllc
Instagram: audioanarchyllc
Youtube: youtube.com/bbeljefe
Well since I can't even get a signal to begin with, I'm suspecting a bad ground. How would you properly ground a probe to your amp? n00b question but hey this is my first time doing something like this.
any ground will work. Bare metal, battery, but why cant you get the probe into where the ground wire goes? loosen the screw and shove it in. Unless you have some weird amp with angled inputs or some thing.
What amp is it?
Hifonics BRX1100.1D. It does have the weird angled ports for the power, ground, etc.
I got mine came with the aligator clip but not with the thing you circled
06 monte carlo
2 12 rockford p3s
soundstream rubicon 2500
crescendo audio mezzo 6.5
ct sounds 125.4
execution audio and shca wiring
2 xs d3400 on stock alt
