99 Infiniti I30 TRunk BoX
Desousa93
baisc ideal... cant do center port because it will hit the sub
1511509_10151938606213549_969669219_o.jp
ported (double the port area) tuning will be high but shrink it with testing to get it where you like
sealed (mount sub reverse)
1622061_10151938606263549_558894332_n.jp
Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
just something quick i threw together not looking at specs or anything just a basic design for a 12" you can make adjustments accordingly
that box looks sick but im trying to port it thru the center armrest.
:domodance: :domodance::morepower1:New Build in the Making :morepower1: :domodance: :domodance:
1999 Infiniti I30 Limited
if you break a rule and argue with n8 your going to get banned. suspended if your lucky.
i just modeled this in winisd.. its peaky but would it sound good on the lows?
1st one is 2.0 ported 1.5 cubed
its going to be hard to port though the center and get the box to work properly and honestly that sub would most likely rather be in a regular ported box
whats hard about it? the sub hitting the port?
why does the sub always go into the ported section ? it cant go in the sealed section?
and do you use google sketchup for your 3d models?
sub goes in the ported section so you can smell it before something goes drastically wrong... its just insurance.. it can go in the sealed but i personally would never run a 4th with the motor in the sealed section lot of people do it though... you can also do an external port but then your seats will have to be down all the time
yes i use sketchup
I like both designs, having trouble with my substage and these are great ideas. Got me thinking outside the box so to speak. lol
yes i use sketchup
You're right. However, I'm sure you coulld face the motor side into the sealed section. I just believe the sealed section should be a little bigger than recommended size.
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
yes i use sketchup
how much bigger if the sub displaces 0.17 cuft
  • Who's Online   0 Members, 0 Anonymous, 2631 Guests (See full list)
