Can i make this enclosure better? Help?
bcbrassard
Thanks Joe X, i didnt know how box size affects sealed tuning vs power handling. So at this point what would you recommend, 2 12s sealed at 2 ohms to get about 700+ watts each of the T1500.
Or i think i could port thru the cab where the speaker cutouts are. Using a 4" or 6" aero port off the same power.
Last maybe a 15" in 1 ohm sealed or ported.
the single 15 ported would give more output then 2 12 or a single 15 sealed. I wouldn't do anything under 2cuft per 12 if going ported.
porting through the deck might or might not work. the port would be loading off the back glass which can affect tuning but could be beneficial to.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   0 Members, 0 Anonymous, 1160 Guests (See full list)
