What to power SA10D2 under 250
lesstutrey
So basically pick between two amps, and one is wayyyyyy less and a bit less powerful? I wish i could find tests of a the Q1-750 doing 1 ohm loads... I was hoping for something more in the 1000w range.. but i guess.. closest i come to that is 1200w it seems. Guess i could get close to that since gains could be set lower than distortion point.
4ohm is little kid games wire down to 1 ohm..
$299 for sundown saz1000d id spend the extra $50
http://www.amazon.com/gp/aw/d/B003ZW7KVC
$199 on a budget hifonics
http://www.amazon.com/gp/aw/d/B0036B8URK
Maybe look used?
:domodance: :domodance::morepower1:New Build in the Making :morepower1: :domodance: :domodance:
1999 Infiniti I30 Limited
if you break a rule and argue with n8 your going to get banned. suspended if your lucky.
2004 Grand Prix GT
(2) 12" RE XXXs (04/05 XBL^2)
5 cu. ft tuned @ 35 Hz
MMATS HD4000.05
MMATS SQ4100
Infinity Kappa components
Juice Box black cherry
Duralast platinum group 34
1/0 KNU OFC, 2/0 welding
Singer 250A
So basically the SQ 750 is underrated, and i guess it's already 25% over power for the SA10.. I could go with a sundown 1000w amp.. but they're 300$ for the SAZ1000 or the preorder on the new 1000w they're coming out with. I'd go for the CT Sounds 900.1, but again, price issue. Seems like the SQ 750 it is.. and that doesn't seem like a bad thing.
its just one sa10 d2?
Yes. Just one SA10 D2.
It's going into this:
th_1459875_10201036436181041_93900290_n.
It's a HIGHLY modified 73 nova.. don't want to add the weight of multiple subs when i can run a 10" that will keep me more than happy. Best i've had prior was 300wrms (last time i did a system it was more like $1 a watt), so i think this will be more than enough to keep me happy. It will get some driving, but far from a DD. I'm gonna do a system in my subaru in time.. once i finish up the nomaro, and the 57 trifive belair coupe (that is just getting 4 comps). Debating not running the RE USX4250 in the nomaro since i have no plans on selling it, where as the bel air i will, and it has shown to put out CLOSE to rated in a review (78x4 full range @ 4 ohm cea2006 bla) and try to find a better 4x100@ 4 ohm for the comps in (two sets of ID CTX65s) and am looking at soundqubed there too. Only issue is the ID's are rated 100wrms, q4 puts out 120, but that shouldn't be too much overpower, right?
Go.with the sq amps, you won't regret it. If the 120.4 is yoo much power you can turn the gain down. Hell I got an ampere 125.4 and am gonna run a set of hertz hsk165s active on it.
Used to have a loud truck
2009 Corvette Z06, H/C/I, 150 shot, g force tune, 730rwhp/690rwtq
2013 F-150 limited, MPT Tune, leveled on 35"s
