What to power SA10D2 under 250
lesstutrey
anyone have links to CT pricing...I only recommended the Soundstream due to the price, I haven't seen the CT pricing for the 900.1
It's 209$
If you can find a 900.1 for $209.00... get it. That price is below the old MAP and those amps are now $329.99.
As for power ratings CT Sounds amps are rated at 12.8 volts, not 14.4. So even though the specs say 200, 400 & 800, your real world power outputs will be higher. As an example, the 1400.1 is rated for 1800 watts @ 1Ω. It did 2406 on Steve Meade's amp dyno.
But none the less, you shouldn't have any problems running at 1Ω with a 200 amp alternator unless you install amps that are horribly inefficient.
ah yeah.. that was the AQ.
It's 209$
gtfo...really? $330? what the fuck
that's the prices I found too...
http://www.stevemead...cherokee-build/
2005 Jeep Grand Cherokee
Alpine CDE-hd148bt
Alpine PKG-RSE2
PRV Audio (4) 6MB200 front/rear doors
PRV Audio (4) TW350Ti dash/rear doors
Kicker KX350.4
Obsidian Audio (1) 18 D4 v2
revamp (2) Stereo Integrity HT 18d2
DC Audio 1.2k
5.25ft^3 tuned @34hz
revamp Infinite Baffle Cpillar
AudioTechnix 60mil deadener
KnuKonceptz & SkyHigh wire (complete setup)
the pioneer gm-d 9601 is on sale. 500rms @4ohm, 800rms@2ohm and 1200rms@1ohm. here is a link http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=pioneer%20gm-d%209601
truthsayer
I have an Audio Technix 800.1, same as the CT Sounds 900.1 besides the voltage meter on the bass knob.
Way under your budget
Meaning you picked it up for less than 250? i know current MAP on them is 330... doubt i'll find one in the 250 range.. but calling tomorrow. Guess the RF R750 might be up my ally too..
Edit: actually for money R1200 probably my answer. Pretty much same specs as a SQ Q1-1200 and the NVX JAD-1200, and i can pick one up for about 220$. Any reason to steer clear of Rockford Fosgate?
No meaning I can sell it to you for less than 250 lol. Wayyyyyyy less than $250. Hit me up. The same exact amp as the 900.1 power wise
The Audio Technix amps are no longer made since everything is CT Sounds now.
Nope, nope, and nope.
