Joe X Posted February 5, 2014 Report Posted February 5, 2014 Ok here is some idea for a dual tuning box, YOU will have to decide you low and high tunings based on your preference and the vehicle's acoustics to maximize SPL: External Height = 24.625 inExternal Width = 35 inExternal Depth = 25 in Wood 3/4", double later baffle. Ports 6" in diameter, 15" in length for the stated tunings. High tune - 4 ports open: Fb = 42.6 HzVb = 8.7 ft^3 Low tune - 3 ports open 1 plugged: Fb = 36.3 HzVb = 8.9 ft^3
SlamminBeats Posted February 5, 2014 Report Posted February 5, 2014 Maybe do a wall? dont wall 2 15s.
Chance_P Posted February 5, 2014 Report Posted February 5, 2014 Ive done setups in cherokees, grand cherokees, and a patriot, and all have had better output from subs and port firing to the rear. I know youve got a compass, but just throwing the info out there.
Chance_P Posted February 5, 2014 Report Posted February 5, 2014 Maybe do a wall? Im doing a wall in my grand with 2x hdc318's. If youre gonna wall it id go with 3x 15's or 2x 18's. 2x 15's isnt enough to justify it since youve got the space to make a box work, imo. If you wanna do it though go for it!
sbg Posted February 5, 2014 Report Posted February 5, 2014 Ive done setups in cherokees, grand cherokees, and a patriot, and all have had better output from subs and port firing to the rear. I know youve got a compass, but just throwing the info out there. ^^ he is right on this one. 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
armysleepr Posted February 5, 2014 Author Report Posted February 5, 2014 thanks for the info guys i think i will stick with the box for now until i get 2 more 15's
armysleepr Posted February 5, 2014 Author Report Posted February 5, 2014 Ok here is some idea for a dual tuning box, YOU will have to decide you low and high tunings based on your preference and the vehicle's acoustics to maximize SPL: External Height = 24.625 in External Width = 35 in External Depth = 25 in Wood 3/4", double later baffle. High tune - 4 ports open: Fb = 42.6 Hz Vb = 8.7 ft^3 Low tune - 3 ports open 1 plugged: Fb = 36.3 Hz Vb = 8.9 ft^3 what size are those ports?
Joe X Posted February 5, 2014 Report Posted February 5, 2014 All ports are 6" in diameter and for the stated tunings all are 15" in length, free airspace in front of both ends is 6" minimum as well. The ports can also be done in a removable module if needed for more tuning options.
Guest Posted February 5, 2014 Report Posted February 5, 2014 wall is useless unless you're doing 4 15's or 3 or 4 18's
