SA-8 V2 Enclosure Frequency - Strange performance or expected?
racer_boy_x
Hi All-
First time posting here, this is a rad place to find info. I know there is a lot of discussion about the SA-8 V2 but couldn't find much info related to my issue. The sub hits really hard on some songs but misses almost all other frequencies completely (a good majority of songs). I have played with the crossover frequency between 35-250 and it makes basically no difference. Is this to be expected or did I build the enclosure wayyyy off? I am a total nube so I appreciate any help that you guys can provide.
Build:
  • 2013 Chevy Volt Hatchback
  • Single SA-8 V2 D2 - Sundown Audio recommended box (attached)
  • Rockford Fosgate PBR500X1 wired at 1 ohm (measured output was 540 according to factory papers that came with it)
  • Amp gain tuned using multimeter approx 25VAC (50hz sine wave test sound)
  • Power/grounds 4AWG / Sub 8 AWG (although all wires had the be reduced to fit the amp doh!)
The enclosure was built exactly to spec from the Sundown recommended enclosure except I added dual 3/4" MDF on the box face but ensured the volume was the same. The jpg is attached of the specs. No air leaks, lots of liquid nail, Titebond 3, hours and hours of sanding. Is this just what I am stuck with? Maybe the port length is way off? Anyway, thanks in advance.
picture doesnt work but that sub should be in a .75 cube box net tuned to 35 hz
Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
Hopefully I fixed the image now. I thoguht the box was tuned to 35hz but the volume seems larger than .75 cubic ft. The cut sheet was taken from their website. Too large perhaps? Thanks for the help.
I am guessing here but it only seems to hit fairly low frequencies, sub 45hz maybe. When it hits it will rattle your teeth. But it seems that 9 out of 10 hip hop songs I play it is barely noticeable that the sub is there. Maybe the SA-8 v2 was a poor choice for an all-around sub? If I hosed up the box spec I am not above building a new box but spent way too much time building this thing that works with 3 rap songs from 1998.
so without doing all the math, because I'm lazy, can u tell me what your net volume is, your tuning frequency, and the port area per foot/port length?
09 Challenger R/T (Audio system under construction):
  • Pioneer AVH-X4500BT (PAC RP4CH11 harness)
  • (2) Sundown Audio SA-8v2 (inverted)
  • CT Sounds AT1400.1D
  • XS Power D3400
  • 40 sq ft. Audiotechnix deadener
  • 1/0 Audiotechnix wiring
  • stock Boston Acoustic 7 speaker amplified system (for now)
  • Sealed trunk enclosure
Build log:
http://www.stevemeadedesigns.com/board/topic/178399-slammed-dodge-challenger-sundownct-sounds-build/
TEAM GOAT
yeah what he said ^^ if its tuned to 27 hz then there would be a limited amount of music that would sound amazing. Plus its tuned quite a bit lower than recommended so that would also explain the lack of performance, you're also a slight bit above the recommended box volume but some have argued this is okay with the sa-8s
  • XS Power D3400
Build log:
TEAM GOAT
That makes sense to me. The port width is 1.25". I am a little surprised that Sundown posted the cut sheet and box dimensions when it is so far off for tuning. I should have just used several of the designs that were floating around this forum. I was wondering why nobody had built the exact box that Sundown was recommending.
In any case I will double check all the measurements and confirm total volume. I want to say thanks for everyone helping me out, what an awesome community. When I build the next box revision I will post an update. Now...only to find the time...
  • Who's Online   0 Members, 0 Anonymous, 2855 Guests (See full list)
