i'm new, can somebody plz check this box design?
Don Fiesta
Did some small changes with the extra space for a slightly increased efficiency but either spec will work:
The 45s are 6 cm wide except for the ones inside the port which are 7.1 cm if the front to back pieces are done with a 45 deg slant as shown.
i think ill go with the bigger box, the 90cm width..
bigger volume meens a little deeper bass and more efficieny right?
will you make a sketchup design for me for the big box plz?
grtz!
I just updated the sketch to an actual dimensions version.
grtz!
ok ty, ill try to make it in sketch up by myself, and i wil post a screenshot here, so you can check it for the final time so im sure i dont make mistakes, will you check it then?
grtz!
Hey joe, want to say thanks again for helping me with a box design . I was wondering if you could come up with a design for a slot port for me? And could u tell me what subsonic filter 28hz means? I would gladly pay u by PayPal or visa or cashiers check thankyou -jake
grtz!
grtz!
I have just done a custom sketch for you with dimensions, find it here:
http://www.stevemeadedesigns.com/board/topic/182409-im-new-can-somebody-plz-check-this-box-design/page-2#entry2707787
grtz!
grtz!
thank you, i made the design in sketch up by myself and all the measuremants are correct!
1 question, the extensions of the port are 19.25cm, that is 192,5 mm.. i cant cut mdf on 0.5mm is it oke if its 19.2cm or 19.3 cm? its only a half mm..
grtz
Of course you can round it off, even staying within 1 mm of error is really difficult, just do the best job you possibly can and it will be good enough.
The 45s inside the port are difficult to get right take a look at how those should be done:
If you can't do them right better don't do them.
  • Who's Online   1 Member, 0 Anonymous, 2183 Guests (See full list)
